The winch is roughly 8.5" thick, this mount should put almost half back in the grille. It should be pushed back within an inch of the core support, I'll also have to modify the hood latch support to clear the winch. It doesn't raise the winch any more than necessary. It should end up with the lower mounting bolts around the middle of the frame rail.
You're right it is a lot like a Warn mount so you could probably mod yours similarly. I gave Tom my mount off the old short bed because at the time I had bought some DPI bumpers.
Oh, no a/c condensor - those parts are long since gone.
I've still got a couple of small things to buy for the motor and then poop some money to get the starter rebuilt.
I doubt I'll get anything done on it before the 25th but hopefully things will free up to work on it at the end of the month.
have you been able to get any more work done to it? im sending you a pm as well haha
I have to admit, it's taller that I thought it'd be.
It was already dark so I quit and put everything up.
