91 K5 -Procrastination Build - bikini top!
That whole fuel injection thing was FUNNY! That's why I want to upload my daughters video because you can hear it. :haha:
Ok, so here's a little after the fact update...
First, I finally installed my Spicer locking hubs (broached to 35 spline).
There are 2 O-rings you can replace, on the knob and the bezel.
Info from Pirate4x4
* Small O-ring between dial and cover:
AS 568A No. 140
2 1/4" i.d.
2 7/16 o.d.
3/32" round cross-section diameter
Material- Buna-N 70
* Large O-ring between cover and wheel-hub:
AS 568A No. 043
3 1/2" i.d.
3 5/8" o.d.
1/16" round cross-section diameter
Material- Buna-N 70
I took these numbers to Motion Industries and bought enough for 2 pairs of hubs for less than $3. :pimp:
I installed my fender liners. I had to chop some off of the front and the rear since my wheel openings are cut out pretty big. I also had to cut a hole for my battery box to poke through (hindsight: I should have placed my battery box higher on the firewall).
First of 2 short videos -
Do those Spicers work?
I suppose in just installed condition they might.
Martin
Hard to turn (like usual) but they work great.
Video #2, same hill but my wife (doing a better job of) driving
Shoot, looks good dude. Get that cage in there and start enjoying that sucker. You spent enought time building it, start enjoying it! :waytogo:
I'm not a hill climber at all so I thought it looked a little tough but I guess not. Next time I'm thinking about trying a different line that looks nasty. We'll see...
Big step today, I chopped the top! It's not welded together yet, I'm going to have the "new" frame media blasted and then re-do so seam sealer first. I'm also going to work on the cage before finish the windshield frame.
The old glass was all cracked up before I took it out so I haven't messed with it but my top to bottom measurement at the center of the hole looks really close (maybe 1/8" big). I still need to take a grinder and trim each post a hair so they fit squarely together, I think that'll make it just just right. Whew! :D
