Got some more welding done last night. I ordered up some of the weld washers from Ruff stuff, those guys are always great to deal with. I also got one lower bracket into place, just need to tie the new frame, old frame and bracket together now.
I sold my warn xd9000i because I needed a lower profile winch, which I received on Monday. It's a smittybilt xrc10. Have read the solenoids leak water, and after looking at the gasket I can see why.
So I filled in the channel with rtv and covered the connectors where they come out. Also covered them with liquid electrical tape. Hopefully this helps. They did just release the X2O (water proof version) but it is $649 where I paid $399.
Here is the screen shot from using the 4 link calculator also. I think what should be the final numbers are looking pretty good. Any suggestions are always welcome though.
So I filled in the channel with rtv and covered the connectors where they come out. Also covered them with liquid electrical tape. Hopefully this helps. They did just release the X2O (water proof version) but it is $649 where I paid $399. Here is the screen shot from using the 4 link calculator also. I think what should be the final numbers are looking pretty good. Any suggestions are always welcome though.
Anyways i can move the lower link down on the axle a bit and also can probably pick up 1/2" upwards at the frame. I was just trying to keep them as parallel as possible. What exactly does the anti squat do in the front anyways?
