I will give that a look once my links get here. Hopefully that would be enough. Thanks for the tip. Any other advice before I weld everything up?
Cycle the suspension, cycle the suspension, cycle the suspension, cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension, cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension, cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension, cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension, cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension, cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,cycle the suspension, cycle the suspension,
Then about the time you think your done and ready for final welding, go back to the beginning of this post
Do all of you cycling with the real pieces in and tacked real well. Take it past full bump, and droop, then articulate it a little ways past you limit straps and shocks. Check every single position multiple times. Don't be afraid to take a big step backwards to make something better.
install the drive shaft and check it for binding at every limit, make sure that your shock tabs are spaced far enough apart to not hit the shock eyes. Articulation takes a lot of room up where you think that you have plenty.
I would plan for a bump stop now, by bump stop I mean air bump. Their big and take some planning. A king 2.5" bump is 2 3/4" OD, and like 9" long in the fully mounted position with the mounting can.
Then buy a bunch of shock tuning stuff and plan to get sick of playing with shocks.
Did I say cycle the suspension.
It's not hard to link something, it's real hard to link something right.
