97 Tahoe 2 Door
Discussion in '1992-Present Chevy & GMC models' started by skunked, Feb 19, 2015.
  1. Russell
    Russell LLY Escalade Status Premium Member GMOTM Winner
    Jun 23, 2000
    8,132
    852
    Edmonton, Alberta
    Build(s):
    Leaf springs worked awesome for me. But my mistake was putting in 52s. If I went with the stock 47" front springs, it'd have been a great daily driver.
    Coilovers turned my Tahoe into a trailer queen due to geometry issues.
  2. skunked
    skunked Orange Block Because Chevy Premium Member GMOTM Winner
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    Yeah it might be overkill in some perspectives.....
    But I really want something that rides and handles really well on and off the road. Not to say that leafs can't do that, however a linked setup with the right coilovers and swaybar is going to do a much better job right?
    Who knows, I might change my mind and go with a higher end leaf spring but this is where I see things going as of now.
    I should probably re-read your build thread, I vaguely remember some of the debacle you dealt with. At least Penny can tow a load when $hit hits the fan though.
  3. Kay86K5
    Kay86K5 1/2 ton status Premium Member GMOTM Winner
    Mar 9, 2012
    2,737
    1,908
    Emmett, ID
    Build(s):
    Yes, a link setup, if set up correctly, can do better all around as you mentioned, however what people tend to forget is that getting a link setup to that point usually takes A LOT of test/tune time to make sure link geometry is correct and also getting the coilovers setup with the correct springs/pressures to work for you needs (limiting body roll, etc.)...which usually increases the time and cost of builds way farther than people anticipate.
    It just seems very very unnecessary for the overall use of the truck. Would it be sweet? Absolutely! But you can get really close to the same performance and still good road manners out of a good leaf setup.
    Just something to think about. Either way, I'll be watching!
    skunked likes this.
  4. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    11,661
    9,140
    Toe-peek-ugh, KS
    Build(s):
    3
    Glad I stayed with 47" springs then!
    Kay86K5 and skunked like this.
  5. Kay86K5
    Mar 9, 2012
    2,737
    1,908
    Emmett, ID
    Build(s):
    Yeah if it were me and I was already planning on spending the $ on high end coilovers...I would put that money into a really good ORD set of front springs that still have great road manners (to keep the wife happy while driving around town) but gets you the desired off-road capabilities while keeping the simple and proven leaf sprung SAS design.
    If you were building this to be your next trail truck then I would be all for linking it (the mid-90's chevy trucks are just begging to be linked in the front...lot easier than the square bodies). But once again, going back to the uses of the truck....ORD springs would be more than enough to accomplish it
    At this point, you can tell me to :sign4: if you want...:D
  6. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    I don't mind constructive criticism and I'm sure I would be happy with a high end leaf setup with quality shocks. Like you said, these trucks are begging for a link setup but that may not be easily accomplished with a small lift. I'm sure this rig will go on the rubicon at some point......
    Last night I cleaned the deck of the block so it's all prepped for the new heads. Called the machine shop, they're still waiting on the new castings which should come in today or tomorrow. Need to order the head gaskets today, debating on whether or not to buy new head bolts :dunno: Also put the intake manifold in the parts washer, that damn thing needs some elbow grease for sure.
    Bent77 likes this.
  7. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    New heads, head gasket kit, plugs and injector spider. That was expensive....
    Block cleaned up, note the steam cleaned piston
    Tomorrow I'll get it back together as long as the heat doesn't get too irritable.
    Bent77 likes this.
  8. GWeakland620
    Sep 15, 2010
    11,661
    9,140
    Toe-peek-ugh, KS
    Build(s):
    3
    Good ruck!
  9. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    Ran into a problem today, apparently the machine shop didn't think I needed the push rod guides from the old heads :rolleyes: Maybe I should have removed them....
    Made some good progress otherwise.
    Heads torqued
    Intake manifold cleaned with the updated spider installed
    Manifold installed along with the distributor.
    Kay86K5 likes this.
  10. GWeakland620
    Sep 15, 2010
    11,661
    9,140
    Toe-peek-ugh, KS
    Build(s):
    3
    Nice works!
    brans87 and skunked like this.
  11. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    Forgot to mention that I asked the machine shop about the head bolts and he recommended I replaced them with the earlier version and use a final torque spec of 65 lb ft. Rather than the wierd 55/65/75 degree crap the later model bolts recommend.
    Here's a pic of the manifold with the factory spider that used poppet valves. The newer version utilizes injectors.
  12. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    Just got off the horn with the machine shop about the missing push rod guide plates and he said I shouldn't have any? He wanted to know what rockers I had to know for sure, of course those are at my house so I need to run home and call him back. He mentioned that some aftermarket heads had guide plates but these do not need them unless it has a certain rocker design. The pushrods are hollow, I do remember that much.
    @bent72 or @wetoolowdingbangow or @Russell are you guys familiar with any of this?
    wetoolowdingbangow likes this.
  13. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    Found this info on Super Chevy about the Vortec heads
    The Vortec head also uses guided rockers to position the rocker arm over the valve stem. If you choose not to run guided rockers, then you must add guideplates to the heads with screw-in studs.
    So I need to make sure I have these guided rockers.
    Really makes me wonder what heads were on this engine since I had guide plates and apparently the vortecs did not come factory with them.
    Bent77 and wetoolowdingbangow like this.
  14. wetoolowdingbangow
    wetoolowdingbangow 1/2 ton status Premium Member
    Nov 30, 2014
    4,629
    3,024
    East Bay, Ca
    Build(s):
    Yeah guide plates are a bit weird on oem.
    I didn't have them on my 4.3l vortec...
    My 350 didn't have them before but it does now as the aftermarket, screw in stud heads have a way bigger hole than is acceptable for 5/16 pushrods...
  15. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    these heads have the bigger holes so there's plenty of clearance for the pushrods. I'm going to run home and look at the rockers at lunch, hopefully they're guided.
  16. wetoolowdingbangow
    Nov 30, 2014
    4,629
    3,024
    East Bay, Ca
    Build(s):
    They should only have .020-.030" clearance over the pushrod. If they're bigger then you need guide plates for sure.
  17. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    My understanding is that it doesn't matter as long as you have a guided rocker. Otherwise you need guides to keep the pushrods in place which will then keep the rockers over top of the valve tips.
    Bent77 likes this.
  18. Bent77
    Bent77 Black is the new Orange Premium Member GMOTM Winner
    Dec 3, 2002
    17,878
    19,019
    colorado
    Build(s):
    This
    skunked likes this.
  19. skunked
    Feb 27, 2013
    12,326
    11,879
    Placer County CA
    Build(s):
    so I have guided rockers, no idea why I had push rod guides too.
  20. Bent77
    Dec 3, 2002
    17,878
    19,019
    colorado
    Build(s):
    Go fast motor.
    Ironically, early small blocks had neither. Some how they rarely had valve train issues
    skunked likes this.
