buckallred
Registered Member
- Joined
- Feb 11, 2013
- Posts
- 64
- Reaction score
- 15
Several years ago, installed the DIY4X competition dash with autometer gauges.
I didn't realize that in 1989 the vehicle speed sensor (VSS) was a small green plastic gizmo attached to the back of the OEM dash/speedometer unit. I tossed the VSS, and even if I had it, I don't think it's possible to make it work with an autometer speedometer.
Result: Everything looks great, vehicle runs fine, but the check engine light (CEL) pops on randomly. So far I have passed smog twice Just out of dumb luck. All that would take is for the CEL to pop on and that's an automatic fail as far as smog goes.
So I bought an aftermarket vehicle speed sensor (VSS) made for the 1989 Chevy 350 TBI system. It's a metal gizmo that attaches to the side of the transfer case and spins when the vehicle is moving, same as the speedo cable. Then the speedo cable attaches to it. The VSS has 2 wires that run up to behind the dash that essentially send a pulse to the engine control module/engine black box thing.
So I did all that. Problem is, it's not working. CEL still pops on.
The instruction page is attached. You'll note that it says to "connect the brown wire to one of the wires on your speed sensor. It does not matter which wire you connect to it (polarity is not important). Then it says to "connect the remaining wire on your speed sensor to an ECM ground wire."
See photos. I attached one of the VSS wires to a brown wire that I believe is correct. Although technically it is brown with a white stripe. So it may be totally wrong! It is one of 3 wires that had a plastic click type fitting on the end of them. I cut the fitting off. The other 2 wires in the plastic fitting are pink / black stripe and black / white stripe. As I'm sitting here writing this, it occurs to me that "brown with a white stripe" is totally different from "brown," and that's probably my error. I attached the second VSS wire to the black / white stripe wire that is located right next to the brown / white stripe wire, and was running to the same click type plastic fitting.
Ultimately, I need to find that brown wire. Then, I need to know what "an ECM ground wire" means. I can ground something to the vehicle's body, and a ground is a ground (No matter where located) as far as I know, but I don't know how to determine whether a given wire is "an ECM ground wire."
Any help is appreciated. Obviously I have no idea what I'm doing and trying to cram my hands around behind that dash is awful and I pretty much effing hate it. As much as I love the vehicle. And yes I hate California and I hate the smog system and I hate our governor and I hate everything about it all. Thanks!
