I had the tuffy conse in my last one and i hated how cheap the lock mechanism was i could easily pry it open with my hands. This one it locks onto the edge of the top 3” wide. So it cant be easily pry’d open. Ill end up covering this one in fabric and build a cushion for the arm rest part as well.I'm curious about what you are going to come up with because I have Tuffy console that I haven't used but I don't care for how it's built. I keep thinking that I can rework it to something better.
Well thanks for the information about the lock. I haven't messed with this one at all. It was traded to me.I had the tuffy conse in my last one and i hated how cheap the lock mechanism was i could easily pry it open with my hands. This one it locks onto the edge of the top 3” wide. So it cant be easily pry’d open. Ill end up covering this one in fabric and build a cushion for the arm rest part as well.
It looks like it!I wonder if this is the right dimensions for the switch location?
Rocker Switch Style 4.2A Dual Car Charger Marine USB Outlet
About this item Quick Charge: Dual USB Rocker Switch designed with dual USB ports supporting.USB outlet: 12-24VDC input, power outlet 2.1A & 2.1A.USB socket can intelligently detect your devices and simultaneously charging 2 devices at optimal current.www.daierswitches.com
Might want that...I probably should tackle the fuel sender issue before I leave though.
Well, The way I see it is I have a toddler so we will be frequently stopping. Also, the blazer gets the same MPG as both the other rigs (4runner and Tacoma) so I think we will be fueling all the same time either way.Might want that...
Moving day?
Because I wont have the time to do it properly. We are stacking all the boxes in the garage today.Why not put them in the bed side pannels ?
