Damn I hate wiring. Got the firewall ground attached to the head. Ran a ground from the pulley brackets to the frame using an alternator bolt. Need to find a smaller head bolt for the actual ground on the alternator. Ordered up a bunch of 12/14ga wire to repair the factory harness that’s been damaged. Need to order up so 6ga for the alt to battery. Going to run a cable from body to frame at the rear of the truck. All 0ga. Still need to land a couple of grounds for the wiring harness and a couple of switched 12’s and that will be all done. Like done to where I can turn the key and see it light up and dial in the timing and load the tune done.
Ordered a bunch of little stuff today. New oil dipstick, fuel filler hose, vent hose, PCV and hose, throttle return spring, alternator connector adapter, fuel filler cap, oil filter. So much little crap. Need to order all the fluids, bolts for shocks, bushings for shocks, steering box, extended shock mounts, firewall grommets, air cleaner assembly, stupid crap that adds up.
Anyone around central Texas want to do a wrench fest soon? So much little crap.
