Blazer's 85 Suburban "Twinkie"
My need to be clean in a shop is sometimes so bad I will put a tool away even though I'm still using it or going to need it after I get done using the one that I am using.
But it does make cleanup at the end of the day much easier cuz basically everything's put away already.
Echoing others... nice shop man. :waytogo:
Same same. My OCD kicks in, then I can't find the tools I'm using, because I put them away.
Very frustrating sometimes...
Carnage from Moab
Front driveshaft on Rusty Nail. U Joint left the chat, then the driveshaft slip would not do its thing after spending way to long replacing the U Joint.
So got to drive out in 2wd getting pulled a couple of times.
We cut the end of the splines off to see it maybe that would help and it did nothing.
Carnage from Moab
Another trophy you seem to be good at busting drive shafts.
This right here is the U-joint king. Best tool I've ever used for getting one out and back in. All you even need for n the C it's self. Don't need any of the rings and adapters.
Screwdriver and channys for the rings,and preferably an impact to run it, but a ratchet will do.
And your set :waytogo:
