So the crew cab is going on the suburban frame (just trying to keep up over here)
Yes, keeping Twinkie's frame and cutting the cage off then putting the Crew Cab body on. At least that is the idea right now.So the crew cab is going on the suburban frame (just trying to keep up over here)
No but having it not hit my transfer case mount and having it not hit the front yoke which hopefully the limiting straps will help should make it last a little bit longer although it's been like 6 years how long it's lastedDid they do anything different with this shaft?
No cuz it's been pretty goodIs possible that the shaht hit the member after it came loose?
