At this point, I am just intrigued as to what the super top secret method from Montana entails.![]()
Meh sounds like an infomercial pitch. Willing to "tell everyone" but not us.
The cross shaft is hardened to a bearing-steel hardness. A saw or drill just dances on it.
Same for the retaining pin/bolt. It too is hardened.
Cobalt drills won't even do it - REAL cobalt drills, not Harbor Fright ones!
Have you ever heard of reverse drill bits? Center punch the screw preferably and go slow with the bit. It will drill the pin if you buy the good bit. I've seen a mechanic buddy do it several times over the years. They seem to break for no reason.
Hope it works, Paul
I'll send the answer to anyone who PMs and asks.Meh sounds like an infomercial pitch. Willing to "tell everyone" but not us.
My Milwaukee brand cobalt bits ate the cross pin and the lock bolt for lunch.
I center punched the cross pin amd started drilling with a small bit ans worked my way up to a 1/2" bit. My bi-metal hole saw ate the cross pin up too, like it was nothing.
I'm going to bed, and tomorrow is a fishing day.
I'll be back tomorrow evening.
So, I would need oxy-acetylene to get it hot enough to just remove the hardening (anneal?). I didn't realize that I had to get it that hot. Do you think that softening the pin would help stop the pins from breaking? This is just for future reference, my 10 bolts do have the pin, don't they? It won't hurt my feelings if you said no, from what I've heard here, they have enough problems already. I probably don't need to worry about it since I haven't been able to mess with it in a month or more.
Thanks for the info, Paul
