buggy build thread.. F-ING TRANSMISSIONS
Friday I will, I just dont feel to proud for some reason :grind: im taking the night off,
tomarrow I pick up the 42's! and work continues.
right now im behind in work so things are going slowwwwwww.
maybe some pics and words will motivate me..im off to harbor freight to pick up 90 cut off wheels:crazy:
the pic above shows new storage space, the inside panel is not inplace yet, access will be from a hinged panel on top, any latch ideas??
this last pic shows the way the chasis was before, I basicly moved some tube around, added some where I felt needed and paneled it. Also I was able to create about 5 square feet of storage for each side by doing so, also have alot of storage under drivers seat as well.
for the real compartments, plan is to move the battery back to the passanger one in the bottom, co2 set up will be on drivers side along with other needed parts. the rear seat will be remoable and will store spare d-shafts and front shafts under the seat..
plan is to have a buggy that can carry full set of spare d-shafts, axel shafts, co2 and tools, water, spare fluids.
other things to be added soon, navigation, rear and front camera, some creature comforts..yada yada
all panels are being welded in now, including floors, I was able to get some handy boat plugs for the floors. also plan to move the air filter into the cab now as well as water proofing as much as I can in the engine bay,
wheel base will change as I figure out the rear suspensiont his week, right now at 112,
other things, 3 link rear with panhard, and these shiny things sway away 2.5 inch coil overs.. leafs up front are superlift 4 inch springs jeep yj springs.
it took me telling her I would take her out to dinner but the girl friend sat in it..hell she even made the vroom vroom noise:laugh: :haha:
a little cold for her though tonight, that and getting in it was interesting. I told her its like getting on a horse..find a spot for your foot and pray you dont fall 6 feet:haha:
:haha: Nice, see sometimes ladies can be good for something besides draining your wallet. So ou got the new roadster version of the crawlers, thats pimpin'. Just kidding, get it finished Iwanna see it in action.
good to see your working on something thats worthy of wheeling with me:doah: now get it done so i can see if it will hold up:haha:
hey since your not caged yet..chop the top and we can wheel our roadsters together..:crazy:
well its 3am, im awake and firing up the grinder:D good thing im in a commercial area:eek1:
now i have to wait for the ups guy..
powertraxx locker for the front dana 60 ordered
quickcar full prewired guages with warning lights and memory tach
quick car racing 5 switch panel with lights and fused switches and push button start
battery **** off prewired panel with nascar steering wheel kill switch button prewired to the distributor
2 guage gold plated remote battery wire kit will all crimp thingys and other crap
steel braided oil pressure sending unit hose
dual rate sping kit with progressive rate 3rd spring for my 2.5 inch sway away race runner shocks
poly performance pirate style dana 60 flange kit
custom cut weld on rock ricks for the h1 rims/ scull design by copper head fab
nylon h1 bead lock insets from usa 6x6...****ty service and its already been 2 weeks, the guy brendon on the phone had no idea what they were, what i mment when I asked about the o-rings for the rims, and it took 15 minutes to confirm the price I was reading off the website...very scary and I wonder if il get them any time soon..:(
do u have the balls like me to do it:haha:
custom h1 rock lock rings, I wanted a punisher skull but he came up with this.. i like it so much I may put rock rings on my 07 work truck:D
got some of my electronics in..
guages. water/oil and memory tach
battery disco
warning light sending units for oil and water temp
remote battery 2 guage wire kit
steel braided oil sender line "no more cracked copper or plastic ":laugh:
buggy build thread..more parts and progress
  1. got my locker for the dana 60, they have the best waranty,i plan to let my big block and 42's flanges and chromo shafts give it a runs for its life
flanges from poly performance, 35 spline to use with the chromo shafts :) match the rims well.
prewired switches, fused with lights and push start matches the guages and master dico switch
also got in my dual spring rate kit, tender coil kit and coils from poly performance as well
this weeked, finished up the side tube and panels, as well as the firewall and started on a cockpit/fighter jet style guage assembly out of 18 guage, aslo got the tires and wheels on
need to still order seat belts and replace the front seats since they are faded and compared to the rear bench look like arse. also need to get the rear links, finish the rear suspension fianally. make the rear seat mount, do the hydro assist,tube the top, paint or powdercoat and then put it all back together.. sounds so easy:doah:
I also have thoughts of moving the radiator to the back now, hmm more work
tell us more about your switch panel... model #... manufacturer... price...etc.
j
Looks good....:D :D
I've had some bad luck with my poly flanges...
They pop-out from time to time...
The outer splines are undersized, the flange slips by the clips.
I need to get a set of flanges...that are better quality.:rolleyes:
j
the switch panel I got from dansracingsupply.com
call dan up, he sells for less than you can buy direct. he is a real nice guy as well, honest businessman:bow:
anyways, panel is a quickcar, it was around 80.00, killer deal for what it is. they also have some real cool two piece firewall gromets that screw together. Alot of the dirst track parts are sweet:D
480-615-6440
or was it 4660..:doah:
anyways that his number;)
as for the flanges:doah: I hope they hold for me:( they wee the most exspensive ones are the market so they better
I just spoke with Dave, I have the first design.
They did have issues, so they changed the clip size.
Dave is sending new clips...we'll see what happens..
cool, thanks for the skinny. I wonder if he can do them with just plain old black instead of the homoghey checkered flag though... :grin:
j
