buggy build thread.. F-ING TRANSMISSIONS
A winch is the one thing all the buildups have lacked :dunno: Why Shawn doesn't pimp the aluminum hawse and fancy smancy blue line .
small updates.
i want to have it done by the 25th..being that I am on vacation till the 16th though makes it seem like it wont happen. still need to tube the top and make a final decision on the rear links..oh an get a rear axel.. ya lots to do yet. oh and the whole putting it back together part..:crazy:
back on track.. lets just move that date to april 25th.. lol
anyways..
got the big block, tranny and doubler in this weekend, spent a few hours playing with my ruller:crazy: ..uh and figured out my measurements for the 3 link so I can order my links now..and tonights all nighter consist of fabbing a cockpit style dash thingy...
lets see what morning brings as usual..also promissed to have a drivetrain pulled from a wrangler before monday morning..um crap its going to be a long night:doah: :D
Hey Shawn, had a blast helpin' ya put the doubler under the buggy. I know I said the buggy is almost done but that was before you mentioned the stuff you need to change. I was busy droolin' over the watertight welded "bathtub" :haha: and the 42" Iroks! hope I didn't leave any puddles j/k
It's all looking good though, just takes time and more time :D Need any help, just holler at me, I'll see if I can come by.
here is the pics, i might put some glazing putty on the dash to smooth it out, but im happy with it as it is, i can say it is real nice seeing something go from in my head to metal.
Saaweeeeeeeet!!!!!!!!!! :waytogo: Me so jealous :bow: :bow:
You did it better than I pictured it in my head
thnkas again for the hand, the couple hours it took us to get it in there would have been doubled if I had done it on my own..thanks a bunch. cant wait to hack your rocker now:wink1:
The glint in your eye scares me when you're in chop mode...
please be gentle.....
:haha: :haha: :haha:
How about next to your shifter , so you see it when you grab it .
Who needs a gas gauge , fill up before a trip , carry a can on the trailer . You ain't really gonna try driving this thing on the street now are ya :eek1:
supersize75k5 said:
anyways..back to the tech, im thinking about just using johny joints all around on the on the rear lower links... thoughts??
talk to matt about johnny joints. We talked about them when we started planning my links and we have decided on heims for the links because you can get bigger stronger bolts to fit them. My lowers will be 7/8"x3/4" heims & my uppers will be 3/4x3/4 heims.
Harley
If you are DD'ing it, look at some poly type of isolater (jonny joints, spring bushings, whatever). If you are not (and I assume you are not dd'ing it) go hiems. Cheaper and stronger. You can get a 7/8-3/4 that nets some serious strength. Both in the through bolt diameter and the size of the body (how big the bearing surface makes them stronger and last longer). Also lets be realistic. You have huge tires, and a small amount of link separation. That puts an ungodly amount of stress on the joint/link. The 9/16 or 5/8 bolt will cry wolf at some point and that will probably drive your axle into your d-shaft or t-case. It just leaves a lot depending on such a small bolt. Yes the poly absorbs some of the load, but with the tire size and the weight (marv built in a lot of redundant supports with that buggy) I would not want to chance it.
Also carry one spare link if you can. I have seen many fail and usually a spare would save the day.
BTW you can get the 7/8-3/4 for about $5 more than the 3/4-3/4 heims. I think poison spider has a good price.
Finally made up my mind and ordered the material,
2 lower link material
(2) 2 inch tapped and machined aluminum links 20.00 a foot 2 hours lbr =330.
(4) 1.25 chromo qa1 rod ends=239.00
(4) jam nuts=17.16
(8) misalignment spacers =71.92
upper link
(1) 7/8 hiem 28.00
(1) bushing sleeved with dom at chassis end 15.00
(2) misalignment spacers =16.00
(1) jam nut 2.00
(1) tube adapter 11.00
link material..not purchased yet, 1.5 od 250 wall dom is my thought
panahrd
(2) 7/8 hiem = 56.00
(2) 2 jam nuts = 4.00
(2) tube adapter =22.00
panhard material? thinking 1.5 inch aluminum for some bling
so.. 333.00ish in lower link material and labor
and 500 ish in parts from balistic fab
thats about 850.00 before the material for tha panhard and upper link
my girlfriends face when I figured this all out...priceless:D
1.5" .250 wall DOM should be fine for upper links. I would just use the 1.5" .250 wall for a panhard too then take it and have it chromed if you want the bling. :D
Harley
:crazy: hmm, any thoughts on a traction bar set up for the front axle..
im using yj leafs with a big block sitting on em for the front suspension,
wondering about axle wrap
got the lower links back from being built and machined from camble enterprises...I stopped by my dads afterwords and it fell over into his knee..he has a nice bruise and I got a nice laugh BEEF!!!
heres some mud in arizona pics! this is my buddy arrons blazer, 3/4 ton, built 350,sm4665/205 chromo shafts up fronts and detroits all around with 4.56 gears.. his cousin is fabjunkie on here, thought you guys might like these..
I cant wait to wheel again!
ok, back to work.
14 bolt hubs on 70 dually rear, shows the differance, the one on the left is a 70hub, the one on the right in a 14 bolt hub
the upper axel is the 70, the one on the bottom is a 14 bolt
1.25 chromo hiems from ballistic fabrication here in az the lower ones are the 7/8 hiems
this pic shows the towel I was using after I discovered that my dog had been pissing on the hiems for a couple days..while wiping it off I finally puked a littlebit.. "notice towel":eek1: :crazy: :mad:
I dont know if these hiems are cursed now or blessed?:haha:
