Camaro my Brother gave me
Discussion in 'Other Rides' started by cybrfire, Aug 16, 2012.
  1. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,585
    591
    Wisconsin
    Build(s):
    Its possible, what actually matters is the engine relative to the wheelbase and the front wheels, not the cowl. So if you are stretching the front wheels forward more that will put more weight on the back and that does help out no doubt, not only with that but with track handling. Although it appears the front his engine block is approximately even with the back of the front tires.
    I haven't done the math on that, probably isn't far off, but most drag cars at that level do both. Moving the battery back is one of the first things you do. Although these days they have some crazy light batteries, but I can't afford them.
    The only reason I used Lutz's car as an example is because its so famous and easy to find pictures of. If you compare to his other one he built before, it appears to be a foot further back or more, although the new one is made for no prep crap so it may be too far for real race tracks. Somewhere in between might be best for real race tracks. Yours looks more similar to this one below from where the wheels appear to be.
    I look forward to seeing your car at the track, should be a blast to drive. The car is awesome either way so don't think I am being negative, just trying to keep you on your toes so it turns out the best possible for you. :waytogo:
    KirsL likes this.
  2. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    Its all good.
    Honestly, i would have liked to go back a tick further however, my footwell is already crowded, so that was a limiting factor. Plus, gotta be able to work on things and sometimes it may need to be worked on quickly.
    Also, when i say raising the engine up, gotta keep that relative to a "cog" that is a bit fluid at the moment. No matter what it wont be very high but there is an envelope to play within.
    Prep and no prep make for a huge difference!
    KirsL, folkenheath and 76zimmer like this.
  3. folkenheath
    Nov 12, 2004
    4,585
    591
    Wisconsin
    Build(s):
    I hear you there, it appears the yellow 67 would be a PITA for engine maintanance. And although no prep is fun to watch, screw that. I don't want to be purposely driving on a non safe surface just to be crashed into when I am in my own lane or something, they are always crashing. Its like they are taking the safety back out of a purpose built track.
    Last time I was at the track and sprayed it, I blew the tires off, pedaled it 4 times or so and my ET was within .02 of all motor. ha ha. So I talked to the track official and they prepped it right then and there (they said they just scraped it clean to start over from too much buildup the weekend before). Anyway, he said try it again now, (it had only been 10 minutes). So I went back up fully expecting to spin again that night and the car dead hooked, picked the wheels a little, and I was gone.
    So you say you are getting aluminum heads eventually? You staying NA or any power adders in the plans?
  4. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    Ill be sprayin' and prayin'. Caddy big blocks like nitrous!
    folkenheath, 76zimmer, KirsL and 3 others like this.
  5. folkenheath
    Nov 12, 2004
    4,585
    591
    Wisconsin
    Build(s):
    You switching to a single plane intake?
    I didn't even know if anyone made them but I found these...
    https://www.cad500parts.com/catalog/page21.htm
    76zimmer and AgDieseler like this.
  6. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    First season the plan is to run the engine as is. NA and all.
    The aluminum heads, a single plane intake, bigger cam and nitrous.
    Should make for a nice kick in the pants.
  7. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    Front end fiberglass is on.
    Justin V, max 02, 76zimmer and 8 others like this.
  8. folkenheath
    Nov 12, 2004
    4,585
    591
    Wisconsin
    Build(s):
    Looking good!
    What front struts you plan on running?
  9. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    Been looking real hard at the strange engineering double adjustable set up.
    76zimmer and folkenheath like this.
  10. folkenheath
    Nov 12, 2004
    4,585
    591
    Wisconsin
    Build(s):
    (y) Double adjustable is the way to go, Strange or Afco make good quality stuff that works for not too outrageous of a price.
    cybrfire and 76zimmer like this.
  11. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
  12. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    Front end is on. Need some support in a few key places yet.
    83ChevyK5Blazer likes this.
  13. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    KirsL likes this.
  14. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    KirsL likes this.
  15. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    KirsL likes this.
  16. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
  17. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    Been a while since i updated this.
    Front struts are on
    Cooling system done
    Fuel system done
    Brake system all tacked in
    Steering column back to the firewall
    Passenger side header 99%
    Starring in on drivers side header
    Gauges are bench wired. Ready to tack in
    Shifter is tacked in.
    Control panel installed.
    Next up, accelerator, fire suppression, parachute, batteries, wheelie bars....
    wheels87k5, KirsL, Scribbles and 3 others like this.
  18. folkenheath
    Nov 12, 2004
    4,585
    591
    Wisconsin
    Build(s):
    Its looking real good Kert, getting a lot closer, you must be excited!
    It appears you have a shot at this summer? Still a lot of work though, whats your plan?
  19. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    I think youre right. Late summer is possible. I dont know that i have a plan. Just cranking on it for now.
    Working on the drivers side header tomorrow.
  20. cybrfire
    Dec 15, 2002
    15,445
    1,439
    Iowa
    Build(s):
    3
    Drivers side header is done.
    Crank case evac done.
    Starting on some wiring.
