This here screwdriver has dedicated its life to being a spindle bearing removal tool. Straight hits to the bearing and the bend of the screwdriver sits on the spindle wall. No deflection.
I don't think that screwdriver could take the hits I was delivering that prybar last night. I did scrape the walls a little behind one of the races in the hub. Probably just hone it somehow and it good?
This is the spindle bearing tool I was talking about. I believe Lisle Tools was the actual manufacturer but I got mine off of a Snap On truck, the guy sold it to me at cost because neither he or anyone that came on his truck knew what it was so he wanted it gone.
I've gotten no where with the spindle bearing so far. So I went and got the wheel bearing off. It didn't want to but I convinced it. I cleaned it up a little with some steel wool. Now I'm concerned that a new seal won't seal this spindle. If I clean it up real real good will it seal? I'd like to prevent this from happening again.
It’s not pretty but file down the marks, once smooth you can put a seal saver sleeve on it. CR brand makes sleeves, not sure where else but Motion Industries sells them.
