I like the way my cage is setup, but would try to make it a little closer to the roof if possible. Are you tying into the frame or just body cage?
You should try to keep your patch welds close together, maybe an inch or so gaps, then use some body seam sealer....give it a couple days to harden then do your prep and paint for everything.
