good job...![]()
my A-pillar's in the K5 took 6 hr's each...![]()
good fishmouths... how thick is that side sheetmetal gonna be?
That is part of the reason my seats are mounted so low. Great for the desert. But not seeing over the hood while crawling sucks.
how come your not using blue dykem?
So um you gonna take it all apart to fully weld every tube right?
Just making sure you know it's best to fully weld every single joint so those 2 into one your gonna have to give it a quick nip with the grinder so it clears the weld.
It looks killer Adam can't wait to see your arrowhead gussets
I was thinkin that was every time a laid 2 tubes in a corner.... Idk, it can't be that big a difference for the amount of time tearing it al back down lolx
I figured it would be your plan. But I have been asked several times why I took the time to do that. My reply is always cause it's the right way.
Seeing your notches makes me not look forward to Hortons cage. Ugh I love bending tube and really don't mind notching but I am gonna have some doozies if it all goes to plan
Amazing job Adam!![]()
