lak2004
Too bad I work 6 to 6, I'd come and help.
That is too bad.
I should be done "working" at 5 and then as long as i can get some help pushing it into our shop ill hopefully just work on it all night until i am doneToo bad I work 6 to 6, I'd come and help.
Ill get it finished today sometime. Gotta work but at least its in the shop and not sitting out getting snowed on again! Hopefully my bosses dont mind, after all we are a car audio shop and now it reeks like diesel fuel in the back
I'm going to save this thread because I want a diesel Chebby someday and this is a wealth of info.
Glow plugs are #1 for bad starts. Other contributors are slow cranking speed...when the motor turns over quickly the intake charge gets compressed very fast, and this creates enormous heat. That is a good thing. The slower it turns over, the slower the intake charge compresses and the less heat you have. That heat is your 'spark'.
There is a thing called the HPCA (green wires on IP). If it is not working it will be harder to start.
i'd consider running an extension cord out to the truck and plug it in. Set a timer so it heats for about an hour to an hour and a half before you plan to be starting it.
To test glow plugs the quick and dirty way grab a test light. Attach the alligator clip to the + side of one of the batteries. Use the probe side to touch the spade on the end of the glow plug. If the light comes on it's most likely a good glow plug. No light and it's most likely dead. It's not a hard and fast test, but about 95% accurate and will give you a good idea what you're dealing with.
Rene
I started a thread on here about them, just havent looked into it enough yet. What is this HPCA and how can I test it?Get the 6.5L starter brace if you go this route.its just a starter from napa or shmucks... the part number is for a 1994 6.5, which is what mine is. however, its the same block as a 6.2. It ran me about 200 bucks, but its very worth it.
The two starters the 6.2 got were the early style which looks just like a regular sbc starter (but bigger). Known as a 27 MT.
Second style was found in later years, and on all 6.5TD's. Looks more like a mini starter and is a gear reduction unit. Known as the 28 MT.
Get the 28 MT.
Block heater is about $25 at any parts store. You knock out a freeze plug and install the block heater in it's place.
How many glow plugs do you have working?
Rene
