MrDJ
DJ404564X4
OK. My back is ****ed up and will be for another month or two. I don't have the time to work on it anyways, so I'm gonna farm out some work.
Does this list cover it???
REAR AXLE
REMOVE OLD AXLE
CUT OF OLD SPRING PERCHES AND SHOCK MOUNTS
INSTALL NEW SPRING PERCHES AND SHOCK MOUNTS
INSTALL NEW SPRING U-BOLTS CUT TO LENGTH
INSTALL BRAKE LINES AND BLEED
INSTALL SHINY NEW RACELINES WRAPED IN FRESH 35" RUBBER
FRONT AXLE
REMOVE OLD AXLE
INSTALL NEW AXLE NO MODS WITH NEW U-BOLTS AND SHOCK MOUNTS
INSTALL BRAKE LINES BLEED
INSTALL SHINY NEW RACELINES WRAPPED IN FRESH 35" RUBBER
STEERING
WELD IN NEW FRAME PLATES
INSTALL NEW STEERING BOX, BLEED
INSTALL BOLT IN STEERING BRACE
DRAG LINK MAY NEED TO BUT CUT DOWN AN INCH OR SO??
DRIVE SHAFTS
CUT BOTH TO LENGTH
INSTALL
REAR AXLE
REMOVE OLD AXLE
FRONT AXLE
REMOVE OLD AXLE
STEERING
DRIVE SHAFTS
CUT BOTH TO LENGTH
INSTALL
