B
Bent77
Guest
Its still working well
Ehh, you've had Twinkie going longer than I've had a wheeler, so that's awesome!You ProFlow 4 guys make my ProFlow 1 all jealous
Funny thing... I'm having the same exact issue. Will pair, go through the settings for cubic inch, firing order, injectors, etc then it just stays at loading and never gets past 0%. I see it communicates all the sensors in the gauges so bluetooth is working. I've waited like 30 minutes and tried it 2 more times. Power cycled my android and ecu.
funny thing is @Shawn posted in my thread i started on the edelbrock forum today . nate s over there will chime in and help or pin point the problem as he is a big programmer / tuner guy in engineering department by the sounds of it .Still think it's a glitch in the revision. Especially knowing the serial numbers with mine being newer than yours and no glitch loading on the old EP4 tuner software
Will it let you set base timing of 12 degrees? I'm going to get a few more things done so it's ready to start tomorrow. My neighbors are going to love me with no mufflers.fixed it i think .
said screw it on the wizard setup .
main screen .
ecu settings .
load map .
hit check mark after reading the warning .
select pro-flo 4 .
then pick the cal # you want and it will start to load as you answer the ignition firing order setting .
then i would assume you can change the cid setting later in the program under settings . i have yet to get this far . and i cant say it works 100% . but i did this and it loaded up in around 45 sec .
@Shawn good forum over there nice people and solid employee presents .
Just put up a lemonade stand. All proceeds buy mufflersWill it let you set base timing of 12 degrees? I'm going to get a few more things done so it's ready to start tomorrow. My neighbors are going to love me with no mufflers.![]()
heard this story a LOT in the past month . 1 friend almost got banned from f-b for this sticker pic .Will it let you set base timing of 12 degrees? I'm going to get a few more things done so it's ready to start tomorrow. My neighbors are going to love me with no mufflers.
Also... I was at my speed shop last Thursday and some guy was looking over the Holley Sniper kit with the owner of the store. Thinking of all the problems you had, I almost told the guy to walk away but didn't want to piss off the shop owner from losing a sale since I go there alot for last minute fittings I need and it's the only speed shop in town.
Then someone will call the cops on me for no business license. Just saw that shit today on TVJust put up a lemonade stand. All proceeds buy mufflers
Oh you must live “in” Denver lolThen someone will call the cops on me for no business license. Just saw that shit today on TV
Some bitch called cops on 15 year old girl selling lemonaid with no license.
I have 3" mufflers just need to get them welded in with stainless pipe
