Shit...
I do want to go full cable I ordered the pedal as I'm not sure how to set it up so I'll start with the pedal and go from there possibly making my own brackets etc. The engine is in my shop and not going back to the machinist as we're just going to reassemble with new pistons and the parts listed. Static comp was seeing 243psi to 246psiHey I’m the only bent around here! Lol
Why not go full cable on the throttle?
I might have missed it, what was the static compression before it went back to the machine shop?
Not the cylinder pressure, the mechanical compression ratioI do want to go full cable I ordered the pedal as I'm not sure how to set it up so I'll start with the pedal and go from there possibly making my own brackets etc. The engine is in my shop and not going back to the machinist as we're just going to reassemble with new pistons and the parts listed. Static comp was seeing 243psi to 246psi![]()
Supposed 11:1 but I haven't double checked the math it's a long equationNot the cylinder pressure, the mechanical compression ratio
