Just a fluid change.Subscribed
I can help with the TBI stuff. Just did a swap so it's fresh in my head. I'm guessing the switch in the cab before you start it is for the fuel pump?
My plow truck is carb, the crew cab is mechanical fuel injection diesel, the Dodge and sedan alway start.the Dodge and sedan alway start.
It's 0-90 ohms on this one.
I need to pull the needle and "adjust" it.
Use a fork to lift up from the center instead of prying up from one side. They don't break most of the time that way.I shattered a needle once doing that. After that I decided I'd just live with it. Is the "empty" mark also up 1/4th of a tank, or is it just going too high?
Mine would read properly from E-F, but also jump up 1/4 past full when disconnected. Infinite resistance read differently than 90 ohms.
Mine always reads a 1/4 tank worth over actual. I'm pretty used to it, full is 5/4, 3/4 tank is full on the gage and down to empty is 1/4 on the gauge.
