I made my loser start switch with a momentary rocker switch and clamps from a battery charger. I've had it for decades.
same I have an engine start button shoved in 1" green stripe wrapped hose with some zip cord and a couple medium clamps. My Snap On button got stolen in collageI made my loser start switch with a momentary rocker switch and clamps from a battery charger. I've had it for decades.
I have 2 sets of these both sae and metric.bought a set of Pittsburgh forge 1/2" drive deep impact in sae 6 point, some where in mid 80's, when I first started as a flat rate. Used as work sockets for 10 ish years then regulated to home side job sockets, then just to my home projects. Only ever broke the 3/4". My son has them now. I replace the 3/4 with a Snap On, but the rest are all the same mid 80's sockets.
they stood up to IR big torque 1/2" drive pneumatic gun of the early 90s, even a few 3/4" drive guns a time or to.
I am trying....add another truck or two to yard it'll help hide the mess![]()
Interesting, I thought this would not be enough weight to make it work.If ya’ll remember I bought the retractable air hose set up about 3 months ago.
I finally got it mounted today.
Mechanics at work said I could have any brake drum from the scrap bin. While in the bin, I found a piece of a landing gear leg and a piece of 3/8’s plate big enough to use on this.
I spent the day welding it all up. Works great, is mobile with a handcart. Doesn’t have to bolted to the concrete as it weighs around 100lbs.
Works like a champ. You can pull the hose out 90* to the side and it doesn’t even budge.
Already used to air up a few low tires on DD’ers. Hose stretches to the street at the end of my driveway, with one hand. The ratchet is 4 distinct clicks, all doable with one hand.
WIN!
