Nothing short of building a bridge under the body with lumber that you lift possibly in stages, I used my engine hoist first in the back then in the front.So thought could clear all and roll out chassis using 10ton stands with 8” blocks. Not so much. Any ideas on how to separate when you don’t have a lift?
I have a tractor with forks but won’t clear everything to get them in lift and clear
Was my second thought. LolOffer friends beer, 4 larger guys or 6 small ones can lift a blazer body (taking the top off helps)
Sounds like a plan. TyNothing short of building a bridge under the body with lumber that you lift possibly in stages, I used my engine hoist first in the back then in the front.
Extend beyond your wheels so you can roll the frame from under it.
Thanks for detailing my suggestion.If you get some 4x4 posts or other solid lumber that's longer than the body is wide, you can lift the body and put the posts cross-wise between the body and frame. Then the jack stands can hold the body up outside of the wheel track. You'll probably need to do a little carpentry and add blocks to put the support where you want it and not just on the rockers. You can get the jack stands higher and higher with cinder blocks, lumber cribbing or whatever. Assuming you'll be using your floor jack in a non-standard method (extending it with chunks of lumber or whatever), just go a little higher in each corner at a time, such that if the jack were to kick out, it would still be sitting on the other 3 corners and your hands wouldn't be between parts.
Don't forget to disconnect E-brake, Steering shaft, Transmission and T-case linkage, Hood cable, Accelerator cable, Engine wiring harness at firewall, AC lines, heater hoses, Fuel filler neck, Axle vents and probably some other stuff.
You might also reach out to friends to see if they have tall jack stands, or other tools that would help.
I guess that could go in the picture a day thread.On a side note? Anywhere to post functional repurposing parts? My latest endeavor.
Something for enjoying a vice or too between building and progressing with the K5
Be careful to have a strong structure where you attached.I made a bracket bolted to the hinge location. Come along to the ceiling
It’s beefyBe careful to have a strong structure where you attached.
One the homes I bought someone did that and ripped the trusses apart and I had to fix it
Found some lbl and a bunch of block. This weekend she will be pitched on block columns
So ask the right person and you might get a loaner….
