The seal should ride right where you are measuring.
What brand and part # seal do you have?
Im sure you wouldent be the first person on the planet to mix races and bearings ya know.I guess if its on the cheap then what does it matter. Worse comes to worse and you weld the races to the bearing at some point and then you HAVE to change themIm sure you wouldent be the first person on the planet to mix races and bearings ya know.
I just wanted to know if I should knock out the new races and install the old of if it would be ok to drop the old bearings into the new races.
I'd spring for new bearings. One less thing to worry about or have to fix later. They are kinda spendy though if memory serves.
Mixed bearings? On a trail only rig? Don't worry about it, it won't magically explode, I promise![]()
I just dropped well over $1000 in this axle not including the cost of the axle. I don't know where you think i'm being cheap?I just wanted to know if I should knock out the new races and install the old of if it would be ok to drop the old bearings into the new races.
Yeesh calmness I wasent calling you cheap i was saying if you just wanted to drop the old bearings in the new races thats a cheap way out and like some one else said im sure they wont expload on you.
As oposed to the expensive way of buying all new bearings.
Major SNAFU! What the hell are up with my new calipers?
