More big progress this weekend!
Hard lines are done. The brake system is once again a closed circuit.
Got the tires put on and this thing is a once again a roller except with completed suspension and axles.
Bought all my fluids. 205 and Eco are filled up.
Started on some exhaust work. I got this Speedway builder kit and some V band clamps. 3 bolt flanges on the headers are getting removed for V band clamps. I got a bunch of pie cut pieces as well. Getting the exhaust around the front shackle hangers is going to be a bit of work.
Lastly I got this exo cage set down in place to figure out how to tie into the B pillar.
The list gets shorter. Need to get the headers installed so I can get the PS pump installed. The exo holds the PS reservoir and radiator so that needs to be installed. Fuel lines, Battery relocation, gauges, and E fans and this thing should start and run again which is my main goal right now.
