if i recall it was just over 4" long.
Its actually longer.thatK30guy said:Thats much better.
I noticed the bolt tabs for the crossmember mount are both different locations. Is the 4L80E a shorter overall length than the 400?
Shawn said:A 4wd 4L80 short shaft will require a long input NP205 but no spacer is needed and you just need to machine the adapter.
Leadfoot said:Unfortuneately for me, that statement seems incorrect due to the picture below.
http://coloradok5.com/forums/attachment.php?attachmentid=17809&stc=1&thumb=1&d=1141545632
That being said. Who is interested in making a 5/8" spacer for this combo? How much $$$
As soon as I get that part number, I will post it here. When I called Advanced Adapters, they gave me one but it never came up in GM Parts Direct or my local dealers. I found a guy on the 67-72 board that used the RV shaft and I'm trying to get a hold of him for that part number. I hate having to tear in a good 4L80 just to replace the shaft. If the clocking ring gives me .5" then I might be able to use the 2wd shaft if I cut it a little but its hard to say at this point. Its so tempting just to do a spacer and be done with it.MEK5 said:Hey Shawn
I am interested in any info on the RV shaft if you find it!
Trying to come up with a short set-up for 4L80 to short input round pattern 205(LoMax).I have something that I think will work but need to do some more measuring before saying,shoe leather tastes gross![]()
So basically, if I were going to keep my 2wd shaft and use it with a short input 205, I would just need a clocking ring (.5") and the ORD adapter is .25" longer so thats only .5" that would need to cut from the 2wd shaft.sweetk30 said:spacer is easy to make. we just slid case on to shaft and hit bottom on splines and pulled back 10 thds length. it came out to exactly 1.25" thick spacer. and dont forget the 400 oring lip on the adaptor is diffrent size than 4l80-e. we just made the propor size in both halfs of the spacer.
