Here I go
5 degrees perfectly placed might do it. 10 degrees will, for sure.
David
70182647-C9AE-41B4-BEAD-AD9B82680C13.jpeg 9F9EEFED-988F-4BEA-84FA-1E517FCE00D5.jpegSo leaving it straight works fine but I only get about 6 “ of up travel before I hit the frame . Doesn’t seem like much. I’m using a 16” coil over what do you guys think ?
View attachment 363271 View attachment 363272So leaving it straight works fine but I only get about 6 “ of up travel before I hit the frame . Doesn’t seem like much. I’m using a 16” coil over what do you guys think ?
I have about 5 to 6” of up travel from my ride height. My diff to crossmember is the first thing that would hit. (Besides the tires to sheet metal lol) if you look at where the bump strike pad is in relation to the frame, I’d say yours looks about the same?...
Looking at your pic again, is your diff leaning way forward? Looks like negative caster from that angle. If you lean it back, looks like the track bar would clear the ramp of the frame more..??..
looks good. I assume you are zeroing it out from a reference point like the flat belly section of the frame?
Yes I believe I did that right if you could show me an example I’d feel better.
