Lots of info here. Thanks!
Geez can't please you can I. The guy who builds drive lines for a living and is a four wheeler himself was right. Shock!
I don't need more slip than that and I would question if many of us do.
That is great articulation. I actually maxed out the ramp but couldn't get a good pic as I had to stay in the truck.
Yes, the shock was maxed. It is a 14 inch travel shock and was bottomed out on the stuffed side.
The limiting straps are to protect the shock and brake line.
I just post this to prove that the slip didnt extend as much as people thought it would. I was surprised myself but the articulation was great
Didn't know it was going to be limited with a strap, that obviously plays a role in all of this.
You could very well be ok with that strap & d-shaft setup, some trail time will prove that one way or the other.
How did the CV handle it?
. LolHere you can see I was maxing the ramp out and my flex. Rear tire staring to come up. If you look closely the slip isn't even showing splines.
