moneypit_K5
hey obijuan, how did you set up your rear driveline and 208 to allow for so much lift? is it solid u joint conversion on the 208?
purdyI can't resist, here's a teaser pic of my almost assembled build! 3" lift and 37's on H2's:
purdy
89 K5
Stock suspension
33x12.5 BFG AT
89 K5
Stock suspension
33x12.5 BFG AT
GREAT TIRES!!!Front
6" tc Springs, 6.5" Long Shackles w/ relocated frame mount, Zero rates to move the axle 1.5" Forward, on a D60.
Rear
DIY F&S, 6" Long Shackles, 4" Lift 56" long TC Springs with Bottom leaf removed, Zero rate to move axle 1.5" Back on a 14FF.
Rolling 39.5" Iroks on 16x10 Rock Crawlers, More trimming needed and bigger tires wanted........It's a sickness!
