How will my K5/truck look with xx" tires on xx" of lift?
mine has the camper emblem (I think thats what the T'pee one is), bonus cab, and a back seat.
Looks like your back seat was added from a 70's truck considering the velour on the front seat. That and no shoulder belts in the back. Realy nice score for a truck from Chicago area.
I think that Shady's truck is some kind of custom build. I've never seen a crew cab short bed of these types of trucks. Ever. I've also never seen one with half ton axles either. It's almost like they just streched a half ton truck to accept the crew cab. I like it though for sure.
they may have used 2 half ton frames, but it only has one seem in the frame. cab is a 2wd unit I beleive. It IS a hodge podge of parts so it may not have come with a rear seat:dunno: Still finding suprises as I go:rolleyes:
its a cheapo bedliner job.....started with the roof because of sun fade/rust problems. Rustoleum rattle can - sucks on coverage, took 6 cans just for the roof. Duplicolor Armor rattle can - the rest, I think also 6 cans. B**ch to spray, water based, dries forever, lots of runs,any little spot I've missed on prep and it peeled right off, major PITA. But looks better than the roll on stuff from Duplicolor. I will see if I can get water separator for compressor and actually shoot it over with Herculiner or Duraback after this winter.
When I painted mine flat black, I thinned Rustoleum with mineral spirits and shot it out of a cheap Harbor Frieght HVLP gun and it did pretty good. It was WAY easier than using spray cans. I think it only cost me like $60, including all the materials. It's not as durable as a bedliner would be though, that's for sure.
hey hows it going man? my name is jose, i like the top on your blazer i wanted to now where i could get one of those
Original tires were 31x10.5 Goodyear Wranglers
After is with new body mounts, 1 inch ord body lift, 33x12.5 super swamper tsls
Looks good. So, when are you going wheeling with me? There are way too many Jeeps in my club. We need more K5s.
The Black B*tch
The stats:
Front: 8" lift superlift springs, ORD add-a-leafs, extended shackles
Rear: 6" lift procomp springs (52s), shackle flip, 5" shackles ( stock is 3.5 or 4), front springs mount moved rearward 2.5" for shackle angle
Tires: 41x14.50x16 iroks
Wheels: 16x12 w/ 4.375 BS
8" suspension / 1" body
35x12.5x15 ProComp XTreme MT / Western Wheel Cyclones
(roll bar currently out for body lift work)
