I finally got the Buick!
1971 Buick GS455 Stage1
This is just an awesome story an an awesome car, like a dream come true. I like Buicks and I like A bodies.
What are your plans, since it's all numbers matching do you plan to keep it original, or do bolt on mods that can be reversed?
Also, 3 intake manifolds is awesome, plus it must be rare to have a dual carb single plane with dividers, I've never seen a single plane with full dividers.
I feel like you either clean and reinstall the factory intake or if you do the dual carb then you have to do the headers with it, although that lower center header bolt looks like a total PITA.
Awesome car, I will be watching.
The car came with 3 intakes. The original. An Edelbrock B4B, ( which is what came with the Stage2 package), and an Offy high rise, single plane, dual quad setup! View attachment 534330View attachment 534331
I
The original owner worked at a chrome shop in the early 70's. By 1975, a lot of the car was chromed. My plan is to get the car back in the road as he had it in 1975. Leave the chrome, run the original intake, a q-jet with the ram-air air cleaner, and the headers. ( as the exhaust system is set up for the headers and is entirely chromed!)20260921_105730.jpg20260909_081927.jpg
The dual quad setup is my choice. But would probably be the most challenging to dial in. Plus I don’t think I’ve ever seen a setup where the carbs aren’t oriented in the same direction. It’s a killer looking setup but not really providing any increase in power until higher rpm’s come in anyway.
Go aluminum intake.
:sign17:
I noticed that too as I haven't seen that either.
Although, those are not 4 corner idle carbs, and they are mounted on an intake with divided runners. That means if they were both facing the same direction you would only get idle fuel control for one bank with the idle screws. I have converted them to 4 corner idle but it probably wasn't common back then.
I have to agree those dual carbs would look good with those headers.
That engine wants a cam! :waytogo:
Is the original intake cast iron or aluminum? That B4B is aluminum and dual plane, which is nice and probably the best all around intake for that car with a carb.
The Edelbrock B4B intake was used on the Stage 2 Buick kits. With 455, Stage 2 heads, cam, headers, and B4B intake, they supposedly made over 500hp.
:sign17:
Notice only one carb has a choke on it. Which is not uncommon on dual four setups. I’m betting the linkage is progressive too. Meaning it likely runs at low speed on the front carb and the the back carb comes in with more throttle input.
The factory dual four setup on my Dads ‘57 had the choke on the front carb, and the rear carb didn’t come into play until you got deep enough into it. It was a crazy linkage setup to play with.
This one is full on, gas spraying, 8 barrels dumping, quad pumper, economy be damned, 1200 cfm of F everything!!!
That's interesting I noticed the little idle screws but not the giant choke blade on one. :rotfl:
Every dual quad I've ever setup has been even linkage with no chokes because for the most part they supply the runners right under them, so if you start making it come in later you may be making those cylinders lean. And a dual quad setup isn't really a winter setup, I usually use the HP style carbs with no choke tower. The receipt showed two of the same carb so they must of removed the choke from one, I'd probably remove it from the other one too. The linkage appears to have the same ratios as all 4 arms appear to be the same length, plus if they have different ratios you would need a slider or something to let the linkage start to move without moving the 2nd carb as they would have different travel amounts.
