The correct springs on the right look to be like a much stiffer spring than the springs on the left. Is there a noticeable difference in ride quality?
My local Les Swab has the Cobra G/T in stock in those sizes and will do a test fit for free. So if they fit and look right, that will work. Then it goes for an alignment right after tires.255/60 rear, 235/60 front
Or just stay with the 245 rear, but do 225-235 front
Not that I saw on tirerack.No 205 65 available? Or possibly even a 70?
Found a few more missing parts on the driver door glass when I had my glass guy dig into it. Good thing he takes squarebody parts as partial payment.I removed the driver door inner panel. I found the reason the window doesn't roll up all the way, the run channel is worn out and allows the window to move out too far and catch the outer door to window seal. It took some searching, but I found what I need on Year One and grabbed a few other little things needed to get the total up enough for free shipping. That website does not make navigation easy.
