Just tighten the bolts and drive through the northeast in winter for a week. The bolts will be rusted solid and take hours to remove.![]()
I don't drive the blazer in the winter. Otherwise that would probably work just fine lol
loctite
http://www.henkelna.com/industrial/red-threadlockers-permanent-high-strength-12892.htm
"Disassembling requires localized heat (>550°F/260°C), hand tools, and disassembly while hot"
That would probably melt the rubber bushing on the shock mount.
There's no rubber bushings on bling shocks. They have spherical eyelets. Not that heat wouldn't **** with that too.
I think you're on the right track welding tube over the nut and bolt hole. What about torx or that newer spline drive?
Just get some giant "Gabriel" stickers.
Didn't read the whole thread, but along with security nuts and bolts I'd make the heads recessed somehow so they can't get channel locks on there. I can get the fanciest crap off with channel locks if I can get to the head of the nut and bolt. Maybe a welded on protector ring, I've seen it done for zerks and bolt heads.
