L18 8.1L swap resource thread
ATTENTION:
Do not assume that since you’ve been doing this wrench-turning thing for many decades that you will automatically NOT make any mistakes.
If you all will remember, I just got done installing this engine.
Meaning I just did this.
I’ll let the two pictures speak for themselves.
Pic 1. Is of what I found, now that I looked for it.
Picture 2. Is what is left after I made the repair.
Those are the spark plug wires for cylinders 2 and four
Movie Quotes No Gas GIF
ATTENTION:
Doh!!!!
Well, that’s an easy fix! Don’t sweat it dude. That’s anybody’s thrash to get it together and squint just right at the first pic and it almost looks right the way they cross.
So now that you found it how’s it run now?
Doh!!!!
Starts right up, runs a bit rich now, I can smell it. No backfires!
I’ll bet it clears up a bit after it runs for a while.
I’m back to 12+ hours a day at work so…weekends!
Yeah a minor mistake with a 30 second fix is a mistake you can laugh about.
I think I would do the whole battery disconnect/reset thing after that one. Those two cylinders are 270 degrees apart in the firing order so hopefully no harm done as they would both be firing on the wrong cycle, and not 90 degrees early in the compression stroke which could be bad.
