L18 8.1L swap resource thread
ATTENTION:
Do not assume that since you’ve been doing this wrench-turning thing for many decades that you will automatically NOT make any mistakes.
If you all will remember, I just got done installing this engine.
Meaning I just did this.
I’ll let the two pictures speak for themselves.
Pic 1. Is of what I found, now that I looked for it.
Picture 2. Is what is left after I made the repair.
Those are the spark plug wires for cylinders 2 and four
Movie Quotes No Gas GIF
ATTENTION:
Doh!!!!
Well, that’s an easy fix! Don’t sweat it dude. That’s anybody’s thrash to get it together and squint just right at the first pic and it almost looks right the way they cross.
So now that you found it how’s it run now?
Doh!!!!
Starts right up, runs a bit rich now, I can smell it. No backfires!
I’ll bet it clears up a bit after it runs for a while.
I’m back to 12+ hours a day at work so…weekends!
Yeah a minor mistake with a 30 second fix is a mistake you can laugh about.
I think I would do the whole battery disconnect/reset thing after that one. Those two cylinders are 270 degrees apart in the firing order so hopefully no harm done as they would both be firing on the wrong cycle, and not 90 degrees early in the compression stroke which could be bad.
At least yours was that easy. Mine was running before winter and I started it every week for 15 minutes. It went from a split second to start to 5 seconds to 20 seconds to 30 seconds to a minute to 2 minutes to eventually not starting. So it's sad and during this summer I took the camshaft position sensor out and it snapped off in the block. Try getting it out couldn't got mad. My buddy just picked the truck up Sunday and today is Tuesday and he called me finally got to look at it. He got the sensor out and put the new one in and it still didn't run. He was asking me about the harness as he actually wanted to Vin so he could look up the wiring for you. I said to stand alone harness there's two relays on the firewall. Actually on the fender. And he started looking at them and he laughed I had a zip tie too tight and pulled one of the wires loosely off and was barely touching. He told me to get rid of these relays and put the screw on type and he'll tell me which ones to put on. But that was my whole issue..
I went out last night, in the dark, and turned the battery OFF.
I hope my scan tool can do the crank position sensor relearn thing. It’s got a ton of feature that I never use, so, we will see.
If it doesn’t don’t sweat it. There is a non- scan tool process to relearn the crank sensor by driving it. If you need it I can shoot the procedure your way.
I replace the crankshaft position sensor in mine and I didn't even know you had to learn it. I did it while the engine was out so when I finally got my swap done turn the key and it just started up. Interesting
Guy that did my stand alone harness did a hot tune. Starts fast n easy, runs top notch... Egr delete, delete downstream o2 sensors... But 30% throttle is 100%...
If i post link to tune, can someone set it?
The thing with the crank sensor is that it might be very close to your old one and it may be different. There's a tolerance to where it sets the random misfire code. Not having the code doesn't mean it couldn't be better.
I've never heard of anyone successfully completing the learn with a drive cycle.
I've also heard that messing with the LS throttle position tuning is problematic. I get what they're going for, that the response seems bigger, but I'd rather have more fine control.
I have got over 3000 miles on my truck including 3 round trips to Texas since I replaced my crank sensor.
After initial install I jumped on the highway, drove about 2 miles, turned around and went home.
Zoomad told me about the drive cycle, but I'm not sure I even did everything he told me to do.
I drove mine for quite a bit after a new cam sensor. My old,innova and even the topdon wouldn't do relearn. Months latter after getting HP tunners I did the relearn. Not sure it was needed, no codes. Latter when I had the intake off I swapped crank sensors, It was an unknown to me old or updated.
Turns out it had been updated, replaced crank sensor and ran the the relearn.
How are you guys handling the tune side of this? I am at that point where the truck runs and everything I realize as an issue is because it's the tune. I had a hot tune done when I had to harness created 6 years ago. Can't believe it's 6 years later in a truck still not running. Well running but swap not done. He did a hot tune and it runs super rich, 30% throttle is full throttle, but he did do the EGR delete and downstream 02's. I bought HP tuners and it is so hard to figure out but I guess I might have to use AI and we'll sit down and figure it out unless you guys have a good recommendation. I can send someone my tuna if they would like to look at it and give me feedback
I’m not sure what you after. But, I sent my ECM to LT1swap.com, with instructions on what to delete from the programming, and what my expectations were. Which was bone stock tune, minus the items I had deleted, EGR, all but the from two O2 sensors, all transmission stuff, oil level and coolant level stuff. Had them programmed in for the IAC and TPS as I’m running a cable activated throttle body.
It took 2 weeks to get it back and $75.
Thing runs great, super simple, NO BS.
Wow I will check it out that's awesome because every place I'm checking is anywhere from $800 to $1,000
You can always work with the guys from Howell. They did Larry’s original 8.1 tune with the torque management delete, eliminate burst knock retard, no downstream O2’s, egr delete and cable throttle. I’ve that tune in mine and it’s flawless. All you would have to do is send your ecm to them and tell them what you have.
I got Chloe running this morning. She had a discernible miss.
So I ducked under her, found the LH bank was the one popping.
So I shut her down, let her cool off. Pulled the #1 & #4 plugs
#4 looked good, #1
Not so much, completely soot covered.
Plus the porcelain was loose and walking around the center electrode.
I replaced it with new.
Now the miss is no more.
#4 looked good, #1
What you think bout these?
