clstolten
- Joined
- Sep 4, 2002
- Posts
- 356
- Reaction score
- 0
Motor and Transmission Installed
Got some work done this weekend.
Dropping the motor in first. Fit well, but my headers wont work, so I will have to rethink that. The stock manifolds would work, but I would have to remove some of the frame, and that would require taking the motor back out. So, thats out. I might look into the patriot headers somebody else (Mr C?) on here was using on his 8.1.
Had to finish up the trans crossmember that I started building last year. Basically 2x6 3/16 wall that I found at the scrap yard. My np205 will not be clocked up at all, so the crossmember was designed to dip down low enough to act as part of a skid plate belly pan that will come later. When I originally started the piece, I was still going to use my old drivetrain, so it was set up for the sm465, and needed to be adjusted. I drilled two holes with a hole saw for some tube that acts as risers to meet up with the trans adapter. Welded a cap to the top of the tubes and run the 1/2 bolts up from the bottom thru a poly puck, thru the cap, thru another poly puck and threaded into the adapter. The nice thing about this is I could set the drivtrain angle before welding the riser tubes to the crossmember. This thing is beef. Four 1/2" bolts attach it to each frame rail. Had to drill and sleeve the frame for the bolts.
