linked one ton escalade (coming back soon)
Kodiak went into limp mode. Luckily after I drained the water separator it’s running fine. Might grab a new filter soon. The cruise control sucks also but better than none I guess!
I know, I should’ve, and now the trans is acting up, I’m getting a filter and fluid for it... great day
You better get a cat filter adapter for it if it's the same garbage filter as the pickups.
If going with the cat filter and cold weather get a lift pump. Sucking cold fuel through a 2 micron filter is possibly going to shorten the life of the CP3. Would likely be fine but I’m paranoid. There is a cheaper option than the adapter also but it requires a lift pump for priming
Fleetguard filter head? Or similar one.
Napa 4770, $40 and isn’t prone to leaking or cracking like the factory ones. I had an adapter and it came loose every single time i tried removing the filter. So I gave it away after switching filter bases
Made it and set up the camper. This place we parked sucks. It’s so steep, and it’s humid out. I’m a big baby when it comes to being humid. Luckily I’m tired enough I’ll fall asleep. Pictures and videos to come tomorrow!
At the beginning of the video you see my dad locking in the hubs. That’s how far I got in 2wd Then right after this video he told me to go straight right up a very steep wall. Said one Jeep tried and couldn’t make it. I definitely could’ve crawled up it easy.... but there were lots of people watching.... So the front bounce a little while I was on the rev limiter and the transfercase exploded.
That thing is un-natural. Totally impressed on the build and the first run out. It's pretty crazy to see it move like that on the trail. Good work!
So now that you blew up the t-case what way are you going to go? Ford 205? Atlas?
