Rolls Royce
Rolls Royce
Merc??
soo use the body and long block? Throw Portal 9inch axles or unimogs under it and a tube chassis? Blow entire house down payment?Got the 205 tore down and now soaking in the parts cleaner, I’m just going to order already modified rails to twin stick it I think and a gasket kit and 1 bearing. Also planning on cutting off the large mounting foot, or at least trimming it. welding a plate back over that make me nervous though, the welding and cooling down slowly process doesn’t sound like something I’m going to be good at.
Probably going to use a flange style front yoke so I can build a 1480/ Dana 60 shaft front driveshaft. Similar to what @nvrenuf did for his driveshaft. Where’s a good place to order flanges and yokes? 1410 rear also
Or maybe there is a 1480 yoke that will just bolt on to a 205, that would be even better.
Busted Knuckle, WFO, ORD those guys all sell various flanges and I know at least busted knuckle offers a 1480 yoke for the 32 spline output.
This is weird, I was going to message you later. To see where you got yours
My flange is from HAD. I do need a second one still. I think @sweetk30 is selling a pair of them.
Where did you get the adaptor gasket? My 205 kit came with the one on the case side, but I need the square O ring and the trans side one.
Starting to put he 205 back together, put the idler gears in it and there is play in them. Is that normal? Front to back play, like it needs a shin between the case and bearing.
If I turn this thread off, then back on again will I get a VSS tail cone from a 241?
I’ll try and send them in the morningno..... its shim as needed like any other tapered bearing setup . . stephen at ord said zero - .002 end play in the case .There should be 4 shims in the idler setup.
dont forget if you get lost look here .
https://ck5.com/forums/threads/4l80...05-ord-doubler-3-sticked-its-all-done.253000/
and yes i have 2 flanges for sale boys . in the sale section .
