I told him on facebook that he needs something stronger than Adoral...I think you have ADD and need to visit your local physician...
i wont even mention that my girlfriend and i are going to long arm a WJ i bought for her. and build an expedition rig out of it..I told him on facebook that he needs something stronger than Adoral...
Too latei wont even mention that my girlfriend and i are going to long arm a WJ i bought for her. and build an expedition rig out of it..
i wish i knew if a detroit locker from a dana 70HD would fit inside my dana 70 super. i have the detroit already, and i called yukon a couple weeks ago and they said the gears "should" work. probably should have just used a 14 bolt like a normal person would.
Pretty sure it will fit but what you will run into is then one of your axles will be too long and the other will be too short. The super 70 has a odd carrier offset. There is a guy on Pirate in the Dana 70 thread under the Chevy section that put an ARB in a super 70 in his van and had this problem. Might try and ask him what he did about it. GM uses a unique axle pattern that makes it hard to find different length 35 spline shafts for them since most GM full float axles are 30 spline.
thank you! i'll try to get a hold of him. hard to find people that know much about them at all. the guy at yukon didnt seem to lol
His user name on pirate is jolane. 645 is the post # in the Dana 70 thread where he talked about what he had to do. I think he had another thread where he was trying to find out what to do about it. I will look and see if I can find it.
I had a guy ask me if I really thought mine was worth 10k last night. It adds up quick! My 77 that I'm building is adding up way too fast. I passed the 10k mark a while ago. Anyway... this thing is pretty sweet. Keep up the good work and blah blah blah. Lol but really, good job man.Just watched some old extreme 4x4 episodes where they built a "budget" rock crawler for $10,800. i thought i was spending a lot on mine and wont have much more than that in it when its done.
I don't think that the bad news here comes anywhere close to keeping up with the good news!So good news and bad news.
the bad news is, the escalade i was going to buy for the tow rig sold today and i forgot to bid.
the good news is, it didnt sell and they are relisting it.
the other good news is i sold my dodge for $11,500 more than i paid for it today.
and went and dug out the dana 70hd we had with a detroit locker.
thanks to @rksjd8420 and the info he found, i can use a regular dana 70 locker and 2 of the long side shafts from my dana 70S and i have 2 of those axles already and the detroit.
looking into the dana 70S a little more it looks exactly like the newer (1998ish?? and newer) 14 bolts from the axle tube out and has the same axle bolt pattern, but unlike the 14 bolt it still had a dana center section, which looks to be somewhere in between a 70 and 80. So finding an aftermarket axle wouldnt be easy. Hoping these dont break. i'll probably pick up a spare to keep with anyway.
thats a thick ring gear. and the pinion is tiny! 7.17s
