Well I can show you pinion depth change on the pattern
this is the same diff as above but .004" shallower (away from carrier)
and .004" deeper
You can see the heel toe placement moves more than root top placement. Is just that your are not getting a "patch" in your pattern. Be careful with info on FB.
Here are my thought s this morning. Possibly to much marking compound, or poor quality compound. Having some healthy resistance to turning really helps the pattern show
