LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
Picked up some Nason epoxy primer for the roof.
Used air craft stripper on it and then the surface conditioner. Forgot to do the return thing :doah:
Eh.. oh well.
Only found about a dozen of those little spots under the paint, including the ones already shown.
And none past about 8" or so from the windshield.
I'm only stripping to the ribbed portion. So basically just above the front seats. Anything beyond that can be repaired easy enough if I missed something.
Pics later, since I'm at the house right now and forgot to get them lol.
Gotta finish stripping it off yet.
I'm going to take it to clean metal, all the way to the rubber strips, and sand into the factory stuff a ways back to make sure I get anything that touched the ACS off.
After it gets the epoxy primer, I'll do a coat of high build 2k, sand with the rest of the truck... And it'll all get one big coat of the 2k high build before paint, to make it all even.
IMG_20260604_211117793_HDR.jpgIMG_20260604_211116296_HDR.jpgIMG_20260604_211107101_HDR.jpgIMG_20260604_211104945_HDR.jpgIMG_20260604_211100992_HDR.jpg
I put down 3 coats of the epoxy primer.
I'm going to let that cure till Thursday.
Then sand it with 600 grit and clean the rest of the top off.
And paint the entire top with the sealer/primer.
Hopefully final prime/paint, on the 23rd-24th
