LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
More.
And this door i remembered I should take pics of the sound deadening and such too.
Unfortunately I haven't gotten that far yet:doah:
7 sheets of deadener later. Now only one more door to go. Then the rest of the interior comes out for cable routing and floor deadening.
On the other issue with it, the starter is bad. Solenoid is getting it's 12v and going "THUNK" when key is turned, but that's it.
Never realized I forgot the pic in that last one.
And starter changed/batts charged, instead of a thunk the engine spins like it's a fuggin airplane now lol
Well, forkin seat back broke :doah:
So I guess I'm taking it out to see if I can fix it. I kind of wanted to take the front interior out anyway so I can run some wires down the center of the floor. But I don't have the time for it. At least I'll know how to take the seat out for when I do lol
You put the deadener on the inner door panel? I'm planning on adding some deadener, but was planning on applying it to the inside of outer skin.
May I ask why you did it this way? And how well does it work?
I'll bet he did outer door skin and inner skin also... because Might As Well.
-G
-G
Yep I did both. :waytogo:
The more you put on the better.
It's actually a pretty common practice for people,(shops included), to just put a square over the speaker hole, then cut the hole and set the speaker in.
I've never liked that method.
I'm trying to achieve the general sound deadening level you'd find in a New lincoln, or a denali.
I mentioned a while back that this was sort of stumbling every once in a while and going into like a reduced power mode.
Then the other day I was sitting at a stop and it just quit. No stumble, it just quit.
So I read that them are both signs of the PMD failing. I happened to have a spare. So I changed it today.
And now it won't even start :doah:.
I'm hoping it's just because it's cold. But doesn't feel that way.
So I routed a cord around my house and plugged it in, and I'll see what happens tomorrow I guess :dunno:.
Put the old pmd back in, started right up.... So I got forked by an Amazon seller. But it's been a year almost so I guess I'm just out :dunno:.
New Stanadyne PMD fixed it right up.... Even starts better than it has since I bought it.
Only thing I don't like is I got a new #5 resistor with it and it rolls a little coal under heavy acceleration. I'll end up trying to find another #3.
I tried. Didn't get chit done. Mom's in town so we did a lotta drinkin lol.
This is where I got
Another batch of goodies on the way.
Mom went home so maybe I can get some assembly done the next 2 days lol.
Crank is in, 4 pistons completely assembled, and still gotta file the rings for the last 4.
Should have the long block together tomorrow.
Well. Not getting it together this weekend :frown.
Having trouble getting the paper thin oil ring retainers to go in the cylinder.
So I'm ordering a different ring compressor to try again.
Had one pop out under the compressor and catch the block. Which of course bent it and it is no longer round. So there is a gap between it and the cylinder 1/3 of the way around.
So I figured I'll put that to the side, steal one from #8 and order a replacement. So that I could continue for the day.
Got it all back in the compressor, set it in and I held it down good while my buddy tapped the piston down. It paused right at the top for a couple taps, then went in.
But I couldn't push it by hand :thinking:.
So he tapped it in while I guided the rod and it did seem to go ok. Hooked it to the crank and spun it a couple times looking for marks on the wall.... Found some :doah:
One oil ring retainer had folded the end up along side the piston. :angry1:
By this point I was too close to my engine and large hammers to continue forking with it. IMG_20210227_160815494.jpg IMG_20210227_162245128.jpg IMG_20210227_162936786.jpg IMG_20210227_163622605.jpg
Luckily, being forged Pistons they have a large tolerance and that ring is thin enough that it fit in the gap and didn't damage the wall. The marks appear to be the moly coating off of that rings side. There's no actual scratches.
So I'm ordering this one
https://www.summitracing.com/parts/btc-btrrc4065
Because it specifically states it addresses that problem lol.
Tomorrow I'll have to call DSS racing and explain my predicament. Hopefully they can help me out with like a while pack of oil ring retainers lol.
By the way,.... This is the POS I was using.
It worked pretty good for the stock size pistons/rings in my mom's heep 4.0.
Sucked for this though.
