I always jack the front end up as high as I can and let them idle with the radiator cap off and heater on. Does a pretty good job of burping them that way.
Anything above level will work. Obviously the more the better. Also stack 4x4’s on the jack for more height. Or stack the jack on 4x4’s. Extreme measure is unbolt engine and trans mounts and use engine hoist to tilt everything up.I used to have a great spot for that until I did my driveway. Now I just have to use the angle of the road.
New MAP sensor is in. And it's running on it, so that's cool.
I opened the TB vane just a smidge and I can get it to idle now, but it is hard still.
Once it idles it sit there and idle good.
It's getting it to start and idle all at once lol.
It'll get there.
Keep wondering if I have a vacuum leak though. It doesn't seem like it has much vac, and I have a problem with it dieing as soon as I stick it in gear.
Runs about 60kpa at idle. Not sure if that's good or bad lol.
I have the tank out changing the pump at the moment.
I did some data logs idling and a light drive around my loop.
