LSX454 swapped 95 BASS burb.
Little lower, little cooler, bigger sounds.
Might be.. :dunno:
It needed oil primed, and there wasn't any real amount of oil in the chitty shipping pan over the crank. So,... not sure.
I'm kind of leaning towards its burning oil through the PCV system. Even though there's a catch can in line.
I actually vacuumed it finally lol.
There's a few more shows coming up.
Think I'm going to do it again for the ell of it.
2 of them have classes. So maybe I'll get a best in class cause I'm the only one in it or something :haha:IMG_20260827_180643162_HDR.jpg
Well.
I got pulled over again.
This time because the third brake light doesn't work. Again.
I pointed out that it doesn't have one. To which they pointed out that if it came from the factory with one, it has to have one.
Now , I have to come up with something.
I told em the factory one is NOT going back on my roof. And they said it was ok to put one somewhere else.
So....
Do I just put one of the premade ones in the receiver?
Put 2 in the top corners of the back windows where they'll only be seen when they're on?IMG_20260827_213937623~2.jpg
Second time I've been pulled over for the 3rd brake light.
First was a year ago when it was still there just no wires to it.
If it wasn't for the expense of doing so, I'd drill a bunch of holes in my bumper and put like 37 BRIGHT mf's in it.
I have a new bumper waiting to be put in, so it wouldn't hurt this one lol.
I'd have to smoke the lens, or try to find one that is already. :dunno:
Any one that's visible will just p1$$ me off.
Really, the factory one didn't look that bad, I just thought it looked sleeker when it was off so left it that way and welded the holes up.
:dunno:
But, I couldn't sleep, so I went back to the shop and cured the issue.:waytogo:
Mounted a normal 194 build base in a rubber grommet. Bent up a piece of metal for it. And tied it into the brake wire at the trailer plug for now.IMG_20260828_051156020_MP.jpgIMG_20260828_051144681_HDR.jpgIMG_20260828_045201939_HDR.jpg
The 7 way plug is coming off some day, so tied it to the back of that.
In case it needs to be, it's higher than the tails, and they never said it needed to be as bright as the griswald house or anything... So. It's a light. Lol
As soon as I find the right grommet I'm doing the other side too. Then the wiring will get done mo betta.
I ordered two 2" nine LED bullet lights.
I'm going to build tubes that contour to the window that they'll be inside.
That'll keep the glare out of the truck, and keep em mostly hidden from outside.
They'll be big enough I'll quit getting messed with.
And I'm going to put em at the top.
I bought a thing :whistle: :thumb:
I've been wanting to for about 2 yrs.
Now that the grandkids are living with us, I jumped on it while it was on sale and before money gets tighter. LolIMG_20260901_130630661_HDR.jpg
Now, just for a chance to try it..:thinking:
I figured it'll help me attempt learning to tune.
I can run it a few times. Get a base average. Then run it some more after some changes and see what happened. :dunno:
Fuggin hate the test n tune at the drag track.
I want to run, then run, then run, then run... Etc.
Not wait 3 hrs, run, wait another 2 hrs, run, etc.
I have plenty of essentially deserted stretches of road around here.... BF Iowa and all lol.
We got the go pro for trips and canoeing and such.
And I've used it more for this truck than anything lol
Also... You can bet I'm gonna know the 1/4 mile speed of every single vehicle I own :haha:
