So, you're thinking of the stud girdle like mudman83 posted up then?
Rene
Rene
Well, hopefully it works out - there are still a lot of rebuildable 6.2 blocks out there, and a new crank is the way to go.
BKinzey said:Where do you get stud girdles?
I'm sure I've read where guys have replaced the 2 part seal with the single. Are you sure you can't do the same? Nobodys mentioned any machining, just a straight swap IIRC.![]()
Hossbaby50 said:I would also recommend a good 2 micron filter. I have added on to my Dodge CTD and it is a nice easy change since its a spin on. It is much larger then the stock filter and filters much finer. I am now able to go longer without having to change my filter which is nice considering I drive 5000 miles a month. I got my filter from Glacier Diesel Performance.
A bypass oil system would be a good idea on a motor that you actually put some time & effort into. A bypass oilfilter setup will keep your oil cleaner for much longer. You can get bypass setups from many different people including myself if your interested down the road. I will be adding one of the bypass kits to my truck very soon. I really want to be able to extend my oil drain intervals to 30,000+ miles.![]()
Harley
I was confusing the rope and neoprene rear main seals with the one piece and two piece
MaxPF said:You can get one from Kennedy or DSG, but it looks pretty weak. I have no idea where Mudman83 got his beefy-looking girdle - you would need to ask him.
MaxPF said:Well, I solved my piston problem:
tRustyK5 said:so those have been "topped" by 10 thou...so if you don't need to deck the block how much does that lower CR?
Rene
MaxPF said:A close rule of thumb is 1 point per .010". These pistons should give a 20.3:1 CR on a block that hasn't been decked. The decks on my block are flat to within .0015", so I'm not going to have it decked. That should be a good balance between easy cold weather starting and modest firing pressures with 5 PSI of boost.
No piston manufacturer (to the best of my knowledge) makes an 18:1 piston for the 6.2. Mahle's catalog doesn't even show one for the 6.5. As far as I know all 18:1 pistons are made by either raising the pin bore .030" (supposedly Mahle does this with 6.5 pistons on a custom basis for some high volume marine engine builders) or by machining the crown. Kennedy's 18:1 pistons are of the latter type, but rather than simply cutting .030 off the crown they extend the Ricardo cup in a rather unique fashion:tRustyK5 said:Good info! So 18:1 pistons would be about .030" under stock then...
The Kennedy's are. I'm not sure about the others; I think the Peninsulars have hard anodized crowns. Mahle does this standard on stock compression 6.5 turbo pistons. I'm probably going to do this to mine, since I'm not sure of the many different available ceramic coatings, and because hard anodizing seem to work.Are those pistons ceramic coated or anything like that?
Rene
Sorry, I finnally checked. I hope it was not too late.MaxPF said:Hey Mudman83, check your PM's![]()
