Thanks for the print... Have you spun the rotating assembly yet with this installed to verify it clears?
. I don't know if the oil is engine oul that somehow managed to get between the layers, or if the layers were coated with oil prior to drawing the pan. Either way it caused a lot of pinholing in the welds. I could probably go back over it and make it work, but I decided to fabricate a pan from aluminum instead. I will figure out what material I need tomorrow and make a metal run sometime next week (hopefully).
I have a 6.2 I got for FREE and this thread is making me want to build it!
I fixed them with a die grinder and a sandpaper flapper:
.. It has in integral priming pump to get the air out after a filter change. It can also accept a fuel heater if I need it. I think I got a pretty good deal on it
). It also means lower efficiency, and hence lower fuel economy. Finally, the Fel-Pro 6.5 gaskets I ordered only cost $45 for the pair, while a pair of Cometics were going to set me back $250
. Reduced compression is only really helpful if you want to run more than 12-15psi boost. I am going to stay around 10psi and 220HP, so I will be fine with the stock CR.Lower compression means harder cold starting (in some cases, like cold+ high altitude which I find myself in during the hunting season, it can be next to impossible without a block heater, and there is no place to plug in in the middle of the woods). It also means lower efficiency, and hence lower fuel economy.
But the coolant passes through the heat sorce? Is it run off the vehicles feul and elect. system?
If so, you would run this heater a few minutes before startup, correct?
And you can run it like 20-30 minutes, depends on your batterys. I guess with Optima or Exide Deep Cycle 30 minutes is piece of cake. My brother had two 60Ah batterys, and 20 minutes was absolute maximum he could run the heater. Now he has two 95Ah's, and after 30 minutes, there is plenty of juice to start the diesel six.
Max do you have any primary filtration set up for this?
I've got a remote primary set up from a 2000 series detroit if you want, with new filters. I have a bunch of sets kicking around. 20 micron primaries. put on framerail, pre transfer pump. no cash. just shipping to you. if you're interested.
That's quite generous Luke!
Max, nice to see the updates...it looks like it's coming together nicely!
Rene
