Why did you decide to go with a 12.50 wide 33? I thought you wanted skinnier. Doesn't BFG or someone make a 9.50 or 10.50 wide 33?
https://ck5.com/forums/threads/pure-chevy-sex.316597/
Best way to upgrade the studs.
Also if it's a 6 lug 9.5 it requires moving spring perches and shock mounts. As those only came in the newer trucks
I can't remember size but they are tiny. I read somewhere here there was a dorman part number for them. M14-1.5 thAT you could drill out the front studs and install. Ill go back and look for that.Not sure what stud size is in the front of yours, but I tried putting m14's in a d60 to match the rear and they were way loose..
This one from an 89 all looks to be the same. spring perch width and shock locations are good for my 82 gmc. I measured it twice today. Ill measure it again tomorrow. It is a 9.5 14bolt of course I want on the other end of the phone with a tape measure either.
89 Truck would be new body style.Supposedly an 88 or 89 model gmc truck. I won't have it in hand until they deliver it to the shop Friday. Ill post some pics with measurements.
I think he said if I came over And pulled them i could have them and the console for 50 bucks. Might pick them up whether i use them or not. To me they look just like suburban seats. Then again i guess they might be the same as suburban seats.
Pm me the dimensions on them please sir. I might take them off your hands.610-437 is what I tried in my attempt. Got a couple of boxes out in the garage.
Pickup seats and Suburban front seats are the same. But not K5 seats.
