y5mgisi
1 ton status
LOL i take it thats a moan of disapproval?
I cut the exact same hole in mine, and still happy about it. I dropped the tank once before with the stock single exhaust and 1/2 tank. Then again later with dual exhaust and about 1/2 tank again... that sucked. I ain't dropping that 40 gallon SOB anymore!
Took the day off work today to get some work done on this thing. I think by the end of the night it will be pretty well ready to start. I'm waiting on the guy I got the motor from to send me knock sensors and harness as the ones that came with this motor were not ok. They should be here Wednesday. So i think i will just be over prepared for the test fire this weekend.
$5 drill pump from harbor frieght and I just pumped the gas into the two other cars I have. With a drill pump it takes about 5 min to empty a full tank. It would agree it would suck to do on the trail but I'd probably tow myself out anyway.
Best of luck..... I thought about doing the 5.3 swap but a friend of mine at work has a newer truck with 5.3L and tows a boat and said the thing hunts gears while towing. It's the same problem my old motor had. So the other option I could have done was the 6.0L but I chose to just do a 383 instead. But I do like the idea of using much newer technology!
Sounds like you have a fun project.
