So I’m just updating the thread with where I am currently and where I want to be…
But there are questions coming!
Example.
My frame is good around the steering box… but 35s and off-road… and heavy with the camper etc…
Should I get the ORD steering box brace?
Should I do the weld on reinforcement now, or with the brace it unlikely to crack?
Headers fitted great until I decided to upgrade the bolts, because the originals were too short with these 1/2 thick flanges... and they wouldn’t fit.
Some heat and beat ensued… good now
I decided to junk the original AC compressor and upgrade the Alternator from the 63a original.
Lots of reasons...
Original AC compressor bracket it on the header flange... restricts access the valve cover etc..
I bought the ICT billet mounting kit… and started test fitting using the original alternator.
I will Upgrade...
is 140a good enough, or is 200a too much for a V belt setup?
Truck will have 12k winch upfront, lots of offroad lights and 2x chassis batteries...
I am rebuilding the PS pump currently, so I need that all on, and in place before I move on the passenger side.
